Lock sets question
Old Apr 2, 2018 | 07:39 AM
butchc's Avatar
Car: 1988 IROC
Engine: LB9
Lock sets question
Kinda long story so you know where I am at. Prior (short term) owner of my 88 never had a door key for my car. I removed a cylinder from one of the doors and had a key made. Works in the doors and hatch but not the T-tops (which are locked) . I ASSUME that originally it came with two keys, one for the ignition and one for everything else and want to get it back that way.
Does anyone offer a replacement lock set for the t-top cars that has all the required cylinders to change the ENTIRE car over to two keys? Door, hatch and T-top cylinders? Been looking and only finding 3 piece sets and t-top sets separate.
Thanks in advance!
Old Apr 2, 2018 | 10:41 AM
Drew's Avatar
Re: Lock sets question
Take the lock cylinders from the ttops to your locksmith. If your locksmith's place of business looks like any business you'd find in a mall, find a new locksmith. When you find the one with the half crazy, wild eyed, mad scientist looking character, maybe wearing a funny hat, or with a handlebar mustache, maybe an eye patch....... You've come to the right place.
A locksmith. A smither of locks... Can change out the tumblers and make the T-tops match the rest of the car.
I'm only half joking. My favorite locksmith shared a storefront with a dog groomer.
Old Apr 2, 2018 | 11:04 AM
butchc's Avatar
Car: 1988 IROC
Engine: LB9
Thanks Drew, yes I use a real locksmith. I suppose it's in the how too section but how do I get the locked lock cylinders out of the Ttops without destroying them?
Old Apr 2, 2018 | 11:33 AM
Drew's Avatar
Oooh, they're locked? I'd try picking them. Stop laughing. If the t-top locks are like the glove box lock, and other auxiliary locks, they don't have as many tumblers as a door lock anyway. Watch a video or two on Youtube, and give it a go.
It's been awhile since I've looked closely, but you might be able to remove the covers over the T-top mechanisms and gain access that way. I want to say the locks are just pop riveted to the T-top, but you might even be able to just pry the clip off the lock shaft, and remove the pawl.
Old Apr 2, 2018 | 11:48 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
When the Tops are locked in place and there's no key you've got to bust the plastic covers to gain access to the locks because the T-Top locking rod pokes thru the plastic covers at each end.
IMO busting the plastic trim covers off each T-Top is a small price to pay in order to be able to drive with the tops off again !
Old Apr 3, 2018 | 12:03 AM
Drew's Avatar
Ah but they poke through the plastic covers on the body side. The trim on the T-tops is open on the ends.
Old Apr 3, 2018 | 06:21 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
A real locksmith will be able to "pick" the t-top lock, open it and make you a key.
Been there and done that.................
TVP122
Nov 29, 2013 02:01 PM
tpi-hearse
Apr 22, 2007 10:25 AM
12SecondTA
Oct 27, 2006 09:17 AM
GregN
Feb 17, 2002 10:02 PM
