Gear Sets... Are S-10 sets any weaker?
Old Oct 27, 2006 | 12:12 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
Simply question, guy locally has a set from his S-10, 3.42 with no excessive wear, and was daily driven no towing...
are they any bit weaker then the original camaro sets?
Old Oct 27, 2006 | 04:32 AM
Pat Hall's Avatar
They should be identical to the camaro gears. Both are 7.5"/7.625" rears.
Old Oct 27, 2006 | 06:21 AM
Yup; identical in every way.
Their "posi" carriers are a different story however.
Old Oct 27, 2006 | 08:58 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the gears are identical, and if the ratios are the same, its the same part in both 3rdgens and s10s...
however, the higher (numericaly) you go on the ratio, the weaker the gear set will be, simply because of size.
3.42s are decent (for a 10bolt)... 3.73s are only slightly weaker.. but 4.10/4.11s break very easily.
Old Oct 27, 2006 | 09:17 AM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
i have a brand new set of motive 3.42's for sale pm me if interested.
specialized
Jun 18, 2022 09:26 AM
draco
Oct 4, 2015 09:25 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
