Removing fenders
Old Apr 18, 2018 | 08:10 PM
Thirdvert89's Avatar
Removing fenders
Can any one help in removing fenders maybe a video or can u tell me where all the bolts are located. Im not a mechanic doing on my own
Old Apr 18, 2018 | 08:26 PM
Jacobaxeman's Avatar
Car: 1991 Camaro RS
Engine: Hot 355ci
Transmission: Beefed TH350
Axle/Gears: 4:10
Re: Removing fenders
maybe somebody else can provide pictures, but there is a bolt under the car by the door on a tab that sticks down. Then you need to get under the bumper and there's like 4 nuts tucked up in there kind of near the battery box area. Then under the hood there is a series of bolts where the edge of the hood sits. Then there is a support rod you'll see sticking out. Then you pull the bumper toward a tad an the studs will pop out. Pretty easy except for the ones behind the front bumper, those are a pain.
If if somebody jacked up your car wrong and smushed the tab by the door, your going to have to carefully bend it back into place so it is not crinkled and stuck when you remove the fender. Be careful taking it off, it's just flimsy sheet metal.
Old Apr 18, 2018 | 08:42 PM
Thank you for all the info and your time
Old Apr 18, 2018 | 10:14 PM
Drew's Avatar
In rust country, the #1 problem will be rusty fasteners. The nuts/studs along the front of the fenders to the front bumper are probably going to be trouble. Same with the two bolts at the bottom of the fenders behind the wheels, and all the fasteners around the fender liners and filler pieces. Not a fun project for a first timer.
Old Apr 19, 2018 | 12:19 AM
Car: 1991 Camaro RS
Engine: Hot 355ci
Axle/Gears: 4:10
Eh just have to go into it thinking it will be a pain, then you aren't surprised when it's terrible lol.
Old Apr 19, 2018 | 06:49 AM
jworks's Avatar
Car: 1987 Trans am GTA
Engine: 5.7 liter
yeah, its not fun, the studs from the front bumper were horrible, if you have hands any bigger than a third grader it gets rather tight, but technically not a difficult project.
chevy mike
Exterior Parts Wanted
Jun 11, 2011 09:17 PM
ohiothirdgen
Exterior Parts for Sale
Jun 30, 2006 03:55 PM
Alexcoqui
Sep 3, 2004 10:26 PM
