Rust Repair on Body (Front Wheel Wells)
Old Sep 14, 2018 | 10:53 PM
gh0stwr1ter's Avatar
Car: '82 Camaro Indy 500 Pace Car
Has anybody done any DYI work to restore or fix rust holes in front wheel wells on an 89 Camaro RS? I know it shouldn't really matter what car you are working on but I am curious to know what others have done to patch rusted out wheel wells to restore them before starting a suspension rebuild.
Thanks in advance!
Old Sep 21, 2018 | 01:52 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Rust Repair on Body (Front Wheel Wells)
If you have rust holes then you will need to cut out the rust until you get to good solid metal and then weld in new metal. I don't think anyone reproduces the metal so junkyard or just use flat metal. There isn't really a front wheel well though, you have the strut tower structure, a plastic inner finder and a metal outer fender. The outer fenders are reproduced but a good junkyard part will fit better. Any remaining surface rust grind off as much as you can, coat with a good rust converter, sand off the residue, clean and coat with a good self etching primer and paint. You can use truck liner or under coat to finish it off also if you will be driving it in the salt.
Unless you have an attachment to the car though you can go to the south and find a 89-92 Camaro for $1500 with no rust, take all the good parts off your car and put them on that car. Unless you just want to learn to weld.
Dead Reckon
Feb 9, 2012 10:18 PM
84Camaro_L69
Nov 27, 2006 09:28 AM
CamarosRUS
Mar 21, 2006 08:00 PM
fatass
Feb 13, 2002 09:35 PM
ADMZ24
Aug 12, 2001 10:44 PM
