t tops
Old Sep 15, 2018 | 11:28 PM
mcloudy21's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Axle/Gears: Stock
t tops
any one got a good lead/idea on the restoration and or replacement of the acrylic t tops (factory rs 91) can it be replaced with glass
Old Sep 20, 2018 | 09:44 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: t tops
They can be stripped/wetsanded/buffed, but it's an extremely tedious process, and they're still very prone to scratches when they're done.
https://www.thirdgen.org/forums/body...r-lexan-t.html
Best bet is to just get a pair of used glass ones, they fit right in as long as they're from a 1989-92 car. You can use an earlier style t-top too, but you'll have to change the pins out to the larger ones that were used on the 1989-92 cars.
https://www.ebay.com/itm/1989-92-Cam...lbSVia&vxp=mtr
Old Sep 20, 2018 | 11:05 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Re: t tops
Was just reading the other day that GM's Lexan warranty was to replace them with glass tops. Of course, not everything you read on the internet is gospel. If you are not driving it much, and your intention is a correct restoration, then maybe it would be worth your time to restore.
Old Sep 20, 2018 | 11:13 AM
TireSmokin''s Avatar
Re: t tops
With the correct equipment, it's not hard at all to restore them to optical clarity. Any deep scratches and pits can be filled, and when the are finished, they will look better than new.
It does take some time to do it correctly.
Old Sep 20, 2018 | 12:43 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Re: t tops
I have been wondering if I could restore a set I have, too. They're in a 1991 RS parts car and crazed really, really bad. I might try to mess with them and see what I can do. I'm not out a thing if I cant save them
porkyzilla
Exterior Parts for Sale
Jul 25, 2006 10:48 PM
porkyzilla
Jul 25, 2006 10:19 PM
ChrisFormula355
South West Region
Oct 21, 2004 01:53 PM
