cieling carpet
Old Jan 8, 2002 | 12:40 AM
PimpCamaroRS's Avatar
cieling carpet
my cieling is starting to droop kinda a lot now but i am too cheap to take it some where and get it done profesionally for like $50. You guys know any anciet tricks to do it. i have spray adhiesive glue just incase i need it. thanx
Old Jan 8, 2002 | 01:48 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Check the technical articles.
Old Jan 8, 2002 | 07:19 AM
MotoGod's Avatar
It's actually very easy. I just did this a week ago to my headliner.
In a nutshell here are your steps:
1. Take out the headliner
2. Rip off the old fabric
3. Get the old glue and crud off the fiberglass headliner
4. (optional) Give the headliner board a coat of fiberglass resin to strengthen it
5. Put your new fabric on with spray adhesive
I picked up some nice grey fleece like material at Walmart for $5 a yard. I bought a yard and 2/3 and it was plenty to cover both my T-Top headliner and my sailpanels. It might even be enough to cover a hardtop.
All in all it cost me @ $30 total, but I had the fiberglass already on hand ;-)
Old Jan 8, 2002 | 10:08 AM
the tech articles only tell how to REPLACE your T-TOP headliner. i just want to make it so my headlier does not sag. and i dont have t-tops.
Old Jan 8, 2002 | 10:19 AM
MotoGod's Avatar
Should be about the same man. You might have a few different pieces to get the headliner out, but once it's out...same article applies. It's just a boards that needs fabric. Doesn't matter what shape it is....
Old Jan 8, 2002 | 10:20 AM
MotoGod's Avatar
Ahhh...I think I see your dilemna. You have good fabric, but it just sags? In that case, you still need to do the same steps. No way to re-glue the fabric without taking it off first....and if your going to take it off....why not replace it? If it' in mint condition...just rip it off carefully and re-glue it.
Old Jan 8, 2002 | 11:28 AM
Cargasm's Avatar
Finally, something I can help with! I used to do this for a living.. truth is, you really can't just re-glue the fabric. If you look at headliner fabric on the roll, you'll see that there's a layer of foam padding attached to the fabric. When your headliner begins to sag, it's because the foam is breaking down... the fabric separates from the foam (which still is attached to the roof). So if you just reglue the fabric, then you'll encounter two problems:
1) The glue will seep thru the fabric, causing it to look like sh**t.
2) It really won't last very long.. the foam will still be breaking down, and the fabric will just re-separate.
If you're going thru the trouble to take everything down in the first place, why not go ahead and put up new headliner material. Guaranteed it will cost you less than $50, and you'll only have to invest a couple hours of your time, if that. Easy job!
Old Jan 8, 2002 | 12:44 PM
so i cant just get new fabric, i have to get all new foam headliner material?
Old Jan 8, 2002 | 02:40 PM
MotoGod's Avatar
You can use anything you like to cover it. I chose to use fleece type material. It offers more cushion that just plain fabric and looks pretty good. Check this forum..I posted pics of it yesterday ;-)
Old Jan 8, 2002 | 03:21 PM
Cargasm's Avatar
MotoGod's right- you can use most anything you want , really. Just make sure that the material you choose isn't too heavy for the adhesive to hold up (i.e.- stay away from **** carpet and the like ) . If you use a regular fabric, be sure to have a careful touch with the adhesive spray, or at least plenty of fabric to spare. If you decide to try headliner material, it can be bought cheaply at an upholstery shop, or at a piece goods store... maybe priced at $1.50-$6.50 per yard. Be sure to buy yourself a few yards, so you'll have some to spare for touchups or if you mess up. Too much is always better than not enough.
starliner
Feb 9, 2016 08:18 PM
1992Z28!
Nov 19, 2015 07:33 AM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
indygene
Sep 26, 2015 11:21 AM
