What's the best way to remove the original foam padding under the carpet?
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
It's damp and I don't want it to cause any rust. Is there any type of chemical that will dissolve the glue holding it down? Or should I just get a scraper and take it off by hand? Thanks.
Maybe i'm confused, but if your carpet is getting wet, wouldn't it make more sense to figure out why its getting wet and fix that problem then to remove the padding?
The padding is bonded to the carpet and the car. Not exactly easy to move and you don't really want to remove it... its insulation and sound deadening.
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Should have put this earlier, lol.
This is on my project car. The interior is almost completely gone. I need to remove all the padding because eventually brand new padding will take it's place.
PS- It's definitely bonded to the floor.
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: Should have put this earlier, lol.
ambainb
Apr 25, 2016 09:21 PM
Vintageracer
Aug 11, 2015 08:13 PM
