Replacement Door Latches/restoration
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Good Morning,
I'm about done with the restoration of my Camaro but lack a few things. I CANNOT SEEM TO FIND DECENT DOOR LATCHES! Mine were smooth wore out. Plastic worn off latch, rubber inside latch for the door striker stop busted up. Has anyone ever messed with restoring them? Or know of any aftermarket vendors? Thanks in advance!
Re: Replacement Door Latches/restoration
If you dig deep into the books and Google, and pour over the part numbers, you'll find that GM changed the part numbers often. There are no less than three distinct variations of the thirdgen door latch, with no less than a dozen part numbers. Depending on the year of the car, some of the part numbers cross over to other applications that are currently offered as reproduction parts. I won't make a specific recommendation, but if you REALLY dig in, some other GM vehicles use the same latches, like the 1980's G-body, and S10.
At the very least I'd recommend comparing your actual latch, and photos of the reproductions, and take your chances.
FWIW the plastic portion of the door latch is really just a thin cover that doesn't matter much in the grand scheme as long as it isn't jamming up the works. Early thirdgens use the same latch without the plastic.
There was a NOS set on ebay about a month back.Might still be on there, i think the seller wanted somewhere in the $250 range.I was very tempted, but i went with a refurbed set instead.Im a cheapo!
This set (says 82-87, but they fit my 89 fine) https://www.ebay.com/itm/DOOR-LATCHE...IAAOSwSKtajQxj
cwalsh
Exterior Parts for Sale
08-15-2007 07:25 AM
