Airbox to firewall gasket material?
Old Jan 14, 2019 | 11:04 AM
Vachaun22's Avatar
Car: 1986 Trans-Am
Engine: 305 4BBL
Transmission: THM 700 R4
Axle/Gears: 2.73 Stock
Does anyone know where to obtain the seal that is basically taped to the air boxes that seal the heater core and A/C boxes to the firewall? I've been googling for quite some time and everything I have found is very porous foam tape whereas the factory seal is more like a rubberized dense foam.
Thanks in advance for any suggestions.
Old Jan 14, 2019 | 12:38 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Airbox to firewall gasket material?
I couldn't find anything a few years ago when I had to replace the evaporator core housing. I ended up using some 3M strip caulk. Works pretty good.
Old Jan 14, 2019 | 02:32 PM
BigBlock73's Avatar
Car: 90 IROC original owner
Engine: 5.7
I used the Strip caulk as well.
Worked great
Old Jan 18, 2019 | 06:32 PM
roadthrills's Avatar
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
You can find foam and butyl tape at the hvac supply house.......imagine that, sealing up the hvac box with hvac parts lol!
Old Jan 19, 2019 | 05:03 AM
Vachaun22's Avatar
Car: 1986 Trans-Am
Engine: 305 4BBL
Sadly, I never thought of googling for hvac foam rubber gasketing tape. I think that may actually be the way that I try first.
Thanks for the suggestions everyone.
Crusin' 1980's
Mar 28, 2006 05:49 PM
1991tealRSt-topGuy
Dec 9, 2002 11:30 PM
rogz
Sep 10, 2002 08:07 AM
Mkos1980
Jan 13, 2002 07:39 PM
five7kid
Oct 12, 2000 02:03 PM
