How to clean block of head gasket material
Old Jan 13, 2002 | 05:41 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
just ripped off old heads, how do i clean the block of the old gasket? Looks pretty caked on!!
Old Jan 13, 2002 | 05:49 PM
Hellraiser's Avatar
A sharp gasket scraper and a stiff wire brush will work fine, but take time and some effort. 3M makes a good gasket removal pad for use with an air tool, or regular drill.
Try spraying the surfaces with brake and parts cleaner to loosen the crud up a little.... helps with some types of gasket more than others.
Old Jan 13, 2002 | 06:39 PM
ede's Avatar
ede
i use a wire cup brush in a die grinder. there are several gasket remover chemicals too, but i've not used many to recomend one brand over another, and i forget the name, guess i'm gettign old.
Old Jan 13, 2002 | 07:31 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
i had a 2in dia wire wheel on my drill will that work? How to I block my coolant passages? Just put rags in the bores?
Old Jan 13, 2002 | 07:39 PM
Hellraiser's Avatar
Yes, and yes.
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
