Opinion on how to handle spot rust
Old Feb 20, 2019 | 10:03 PM
SliceIROCZ's Avatar
Car: 1990 IROC-Z
Engine: 5.0 TBI
My car is new to me but it has seen some pretty rough times outdoors and is by no means a show winner. It has its share of mismatched finishes (primer black hood, repainted front fenders w/o IROC stripe, IROC stripe elsewhere, peeling clear coat everywhere). It also has several surface rust spots that someone tried to cover up. I'm not ready to repaint the whole care as I am working on the mechanical first (LS/T56/rear swap). My question is, what is the best way to handle these spots? Clearly someone already half-assed the fix once. I want to prevent the body from rusting as it is a solid body aside from the surface stuff. I do have a compressor and paint gun but have never attempted large scale painting of a car before. Picture attached is the largest of these spots located on the B-pillar, about 2" in diameter. Sorry for the rain drops but hopefully its clear that there is clearly rust in the spots. Thanks
Slice
Old Feb 21, 2019 | 07:17 AM
Hawgtied's Avatar
Car: 1988 IROC "The Duece"
Engine: 5.7 TPI L98
Re: Opinion on how to handle spot rust
Surface rust will turn in to fa full blown rust hole given enough time. Now's the time to stop it from spreading. Sand the rusty area and the area around it down to bare metal with 80 grit on a DA or similar tool. When you see nothing but clean silver metal, prime the area with good automotive primer. It should be okay for a little while but remember. primer is a temporary fix and if it's left without a top coat, surface rust will reappear.
Good luck with the build and keep everyone posted. We like seeing folks breathe new life into these cars.
Old Feb 21, 2019 | 02:09 PM
Drew's Avatar
Leave it alone until you're ready to repaint.
Old Feb 21, 2019 | 05:39 PM
DD9TransAmGTA's Avatar
Car: 1987 TA GTA, 1987 IROC 1988 Formula
Engine: 350 tpi/305 tpi/350 tbi
Transmission: All have 700r4's
Axle/Gears: 10 bolt with 3:73's
Scrub the rust with ospho and a red scotch brite pad then seal it up with some paint. Should last a long time like that
Dead Reckon
Feb 9, 2012 10:18 PM
augie1209
Jan 28, 2010 12:56 PM
GuitarJunki17
Jul 27, 2006 05:36 PM
Speedy Mike
Convertibles
Sep 30, 2005 03:35 AM
RockinGTA89
Mar 13, 2005 04:49 PM
