headliner in '87 GTA
Old Jan 9, 2002 | 04:00 PM
gta ta's Avatar
My headaliner is starting to fall down in my '87 GTA. Is there a simple fix like super glue in a syringe or anything? Or do I have to take it in and have a pro do it?
Old Jan 9, 2002 | 11:54 PM
Jza's Avatar
Jza
No, it has to be redone. Temporarily, you can use headliner tacks or thumbtacks, but eventually the headliner will win, and it'll just look ghetto anyway. You can do it yourself, but much like tinting windows, the cost of doing it yourself is almost as much as having someone else do it and do it better, while saving you from the PITA of doing it.
Old Jan 10, 2002 | 01:35 AM
86trNZam's Avatar
Car: 86 TransAm
Engine: 360 SBC 4Bolt / Bowtie Heads
Transmission: T5 NWC Manual
Axle/Gears: Torsen T2 / 3.23
Know what you mean... Mine started to fall to pieces also and got progressively worse with the T-Tops off(All that wind).
After reading the article on this site I got motivated and took it out. I restored the shape and strength by lining the top-side with resin and cloth, then relined it with new foam and grey leather. Bit of a mission but the results were very satisfying.
Cost me aprox' $300.00NZ($130.00US)... Just an option... Regards...
Geoff
Old Jan 11, 2002 | 01:06 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
It's not that hard to re-do the headliner. The worst part is getting it in and out w/o damaging the fiberglass. I spent about $30 to do mine, because I have a hardtop, I had 2 buy more headliner fabric. It's about $11 a yd @ Jo-Ann's fabrics, and the adhesive is the 3M General Trim Adhesive in a white aerosol can. Pull the old headliner out, pull the fabric off and brush the disintegrating foam off. Cut and place new headliner on w/ adhesive. Let dry for say a day or so. Put it back in. Good as new.
Veaceonee
Sep 29, 2016 08:15 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
okfoz
Sep 15, 2015 05:22 PM
MORREALE5
Sep 13, 2015 09:01 PM
blackbmagic
Interior Parts Wanted
Sep 8, 2015 10:36 PM
