1983 Z28 ground effect and panel fit/alignment
Old May 17, 2019 | 10:44 AM
randallp504's Avatar
Car: 1983 Camaro Z/28
Engine: 305 HO
Transmission: 700r-4
Axle/Gears: stock
My car was wrecked and repaired previous to me around 15 years ago. I was wondering if the ground effect was installed correctly. The effect sticks out about a 1/2 inch past bottom of nose and it seems that the 1/2 inch it’s sticking out could be the reason I have the gap on the fender in front of wheels. And the bottom 1/2 of door sticks out about 1/4-3/8 past fender but lines up perfect with rear quarter panel. Any info is appreciated.
Old May 18, 2019 | 09:34 PM
BIRD91ZRAG's Avatar
Re: 1983 Z28 ground effect and panel fit/alignment
I worked on them new, that gap isn't uncommon.
Old May 19, 2019 | 04:19 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The early gfx's are like that.Thats was one of my pet peeves with my 84, you could see the bottom of the rocker below the gfx.
Old May 20, 2019 | 06:31 AM
Saxondale's Avatar
Car: 84 Z
It looks like there may be enough adjustment in the oversized bolt holes that the gfx can be moved back some. The photos indicate fasteners are installed in farthest forward position of the holes.
If the factory clips have embedded into the urethane, then you can remove those clips and convert to bolts and fender washers.
You are likely to be limited by the rearward stud molded into the gfx. Be careful not to break it off. But if you do you can fabricate and bond a new stud where it fits best.
Old May 20, 2019 | 06:39 AM
Saxondale's Avatar
Car: 84 Z
After looking at my car I think you are close to a best fit location.
Huffs_91_RS
Exterior Parts Wanted
Apr 6, 2017 05:18 PM
19CAMARO85
Jan 6, 2009 04:31 PM
flylow
Aug 3, 2007 11:39 AM
92beastbird
Nov 20, 2006 06:22 PM
