Iroc ground effects for an 84 z28
Old Jun 1, 2019 | 09:05 AM
Jpg's Avatar
Jpg
Car: 84 z28
Engine: 350 crate
Transmission: 5 sp
Hello everyone, I have an 84 Z28 and I would like to add Iroc ground effects. I'm wondering if I should go with OE parts or aftermarket. I've read that the OE side skirts will work with some minor modification, and they are available cheaper than aftermarket, they said the bumpers would be a problem though. I'm apprehensive of using factory side skirts and aftermarket bumper covers together....
Old Jun 1, 2019 | 09:11 AM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Re: Iroc ground effects for an 84 z28
The bumpers will bolt right on. You'll have to change the front parking lights, though
Old Jun 1, 2019 | 06:33 PM
Jpg's Avatar
Jpg
Car: 84 z28
Engine: 350 crate
Transmission: 5 sp
Change them in what way?
Old Jun 2, 2019 | 01:53 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
He means you have to use the 85 up marker lights.Most everything will bolt up.The two small brackets at the rear of the rocker gfx (right in front of the rr tire) from your 84 can go on the 85-up in place of the later bracket.On the fender, i think the bracket on the later gfx is a 3 bolt Vs 2 on the 84.You may have to drill the fender.
dgthomps
Oct 3, 2020 11:11 PM
bonylad
South East Region
Jul 1, 2013 06:41 PM
KBeez
Sep 9, 2004 08:30 AM
