Convert ground effects car to no ground effects
Old Apr 12, 2019 | 12:52 PM
dgthomps's Avatar
Hello Everyone,
I am a new member to this forum although I have referenced it in the past quite a bit.
I've got an 89 Camaro RS that I am slowly working on. I would like to remove the ground effects package on the car in favor of the stripped down Sport coupe/Berlinetta type of look. What parts would I need to source to make this happen? In the end I am likely going to be going with some aluminum drag wheels, jack it up an inch or so in the back and pop in a crate 383. I've already sourced a super t-10 setup from an '82. Any advice with the ground effects would be greatly appreciated.
Thanks,
Dave
Old Apr 13, 2019 | 12:48 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Convert ground effects car to no ground effects
Bumper covers to start with, need to be swapped to non gfx.There is a brace that runs the length of the rocker panel below the door.That needs to be removed and your various holes around the gfx points will need to be plug welded.
Old Oct 3, 2020 | 11:11 PM
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
I want to do the same thing to my car.
90iroc5spd
Mar 27, 2007 03:02 AM
Tyrant21
Mar 9, 2004 08:26 PM
moore82nd
Jan 31, 2002 12:02 AM
