parts help please
Old Aug 20, 2019 | 09:44 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
parts help please
I am hoping someone can tell me what these parts are called and where can they be sourced if possible?
There is a what felt like a tar paper seal covering the bolts for the bottom hinge on the passenger side. What is this called please?
There are 3 rubber plugs on the bottom of each door. What are they called and can I find them?
When I took the the door external handle off, the nut on the left has a rubber insert. This is missing on 2 of the 4 nuts when I removed the handles. The rubber part on the right is I dont know what. This same part on the drivers door is in bad shape. Not sure where it goes. HELP!
Old Aug 20, 2019 | 09:48 PM
Engine: 5.7
Axle/Gears: Stock
Re: parts help please
Also asked about these and not sure where I can get the or what they are called. Supposidly they are to mount the front turn signal housings. These have seen better days.
Old Aug 21, 2019 | 02:01 AM
3rdgenzroc's Avatar
Car: 86 Iroc-Z
Engine: 383 HSR
Here is a previous post with door diagrams and descriptions.
https://www.thirdgen.org/forums/body...maro-door.html
Old Aug 21, 2019 | 06:13 AM
beths91camaro's Avatar
Car: 87 Iroc vert, t-top
Ok, let me get looking. We pulled off a beautiful rubber seal from inside one of the cars- I just need to find where I put it.
The second are called drain plugs. I believe I have several, how many do you need?
Third one, I need to get out and check to see what I have on that bumper and bar we just took off.
Old Sep 3, 2019 | 11:14 PM
Engine: 5.7
Axle/Gears: Stock
BUMP
still looking for this parts. HELP!!
Old Sep 3, 2019 | 11:41 PM
Engine: 5.7
Axle/Gears: Stock
my bad, this has the part numbers I am looking for regarding the doors.. THANK YOU!
now for the turn signal mounts.
Old Sep 4, 2019 | 10:19 PM
Engine: 5.7
Axle/Gears: Stock
the door plugs are a no go. But I still need those turn signal mounts.. ANYONE PLEASE?
evilemokid94
Jun 9, 2011 10:48 PM
85berlinetta2.8
Interior Parts Wanted
Jun 19, 2006 07:42 AM
David Culpepper
Aug 3, 2001 02:54 PM
Monkie
Jun 8, 2001 01:25 PM
TransAm86
Dec 30, 2000 10:43 AM
