1984 T/A W62 Trim Color - Silver Color Code
Old Sep 9, 2019 | 08:00 AM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
My 84 T/A is in the body shop being repainted. The body has been sprayed in the original Medium Dark Royal Blue metallic.
We are trying to determine the color code used for the silver Ground Effects.
My SPID sheet indicates Med. Dk. Royal Blue. Met for both the upper and lower body (this is consistent as the body was blue behind the gfx).
Does anyone know the code for the silver paint used on the gfx?
Old Nov 22, 2021 | 02:03 PM
Luke48's Avatar
Car: 1984 Camaro Z28
Engine: 355 SBC
Transmission: T-5 WC
Re: 1984 T/A W62 Trim Color - Silver Color Code
I have the same question
Old Nov 22, 2021 | 06:26 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
What's the code on your SPID, or the stamped tag in your engine bay?
Old Nov 22, 2021 | 07:01 PM
Luke48's Avatar
Engine: 355 SBC
I do not have access to my car at the moment, but when I do is the trim color code located on it?
Old Nov 23, 2021 | 09:29 AM
KEVIN G.'s Avatar
Engine: 305 CARBED
They used to have the 4 digit represent both colors. The first half was main body, second two numbers were accent. (or vice-versa). Then for a while, you actually got the accent color on the SPID with an A-code. Now, it's a crapshoot.
Here's the PPG books of old. There looks like several colors it could be. Your paint supplier should have chips of those possible numbers, if they're cool...you should be able to borrow them and see what you actually have.
Old Nov 23, 2021 | 12:22 PM
Luke48's Avatar
Engine: 355 SBC
Alright! Thank you so much and I will check it when I see my car.
Old Nov 23, 2021 | 03:28 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
According to the my info 84 PontiacFirebird only used two Silver Paint colors WA 8536 Code 17 and WA 8310 Code 15E
http://paintref.com/cgi-bin/colorcod...r=1986&rows=50
kmcn47
Sep 22, 2012 11:42 PM
wbrooks63
Jun 9, 2012 08:42 PM
tigercyberslash
Mar 19, 2008 06:55 PM
vortech305
May 27, 2003 09:38 AM
JT 85 TA 305
Mar 23, 2003 02:40 PM
