Easy way to get at outer window weatherstripping???
Old Jan 14, 2002 | 01:34 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
I am replacing the outer window weatherstripping on both of my doors. I took off the panel already as well as the triangular window filler. I can see that the weatherstrip is held on by like 5 phillips screws, but 2 of them are blocked by the window. What is the easiest way to get at them?? I will probably try removing the window bumper so i can pull the window away from the weatherstrip a little, but is there any easier way to do this???
Old Jan 14, 2002 | 01:40 PM
gmanuel's Avatar
I also need to replace my weather strip. Where did you get your from and at what price. I believe the only way is to move the window out of the way
Old Jan 14, 2002 | 01:50 PM
I ordered the parts from Classic Industries (www.classicindustries.com). They have a Camaro catalog that has just about every part you could need. Here are the part numbers:
G7962 - Weatherstrip RH outer
G7963 - Weatherstrip LH outer
K3195 - Corner filler RH & LH reproduction (goes on triangular window filler, guides and seals window)
Old Jan 14, 2002 | 07:00 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The only easier way is taking out the glass.
You'll need to take out the trianguler filler piece also, there are a couple screws behind that also.
If you have one of those cheap 90º screwdrivers Craftsman tosses in with their screwdriver sets, that helps make it a little easier. Removing the 2 'bumpers' bolted to the door under the doorpanel will give you just enough room to use that screwdriver better. Stuffing something between the glass & outer part of the door is easier than trying to hold the glass too.
Old Jan 14, 2002 | 10:46 PM
Black 86 'bird's Avatar
Car: 1986 Firebird, 2000 WS6
Engine: 2.8, LS1
Transmission: 700R4, T-56
Axle/Gears: Stock, Stock
Classic Industies has some good stuff. I just put in new door locks this weekend from them.
Old Jan 15, 2002 | 10:32 AM
ops32's Avatar
Car: 1983 25th Anny Daytona 500 T/A
Engine: Stock...inoperative... 305
Transmission: Automatic
I just ordered some from gmpartsdirect.com. They were cheaper than any place (including Classic) - $18.54 each plus postage. Part numbers are:
10124264
10124265
Rob
Old Jan 15, 2002 | 01:41 PM
sixtymhz's Avatar
I wonder if this is the same thing I need.
My car was broken into, and whoever broke in. used something sharpe and sliced the black plastic stuff on yop of the door. I dunno how to say what im looking for. When you shut the door, this long strip, which starts from the mirror all the way bacl past the seat belt, keepts rain, water and wind..(becuase now when I drive, I get a whistle sound). Is this the same thing?? And could I replace it myself?? I'm not the smartest on cars.
Thank you.
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:56 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:50 PM
blackandblue02
Sep 10, 2015 08:19 PM
Fronzizzle
Sep 8, 2015 12:10 PM
