C&C TTops leaking.
Old Feb 15, 2021 | 11:15 PM
KR81's Avatar
C&C TTops leaking.
Brand new rubber all round from sunroof dr, and they still leak in the corners, quite a bit. Even with the previous 33 year old rubbers, they still leaked in the same spots. There doesn't seem to be anything I can do without making improvements but I have no idea how to even start.
I also recall one time reading a thread here with comments from a guy who cut and installed the c&c tops and he said none leaked when they left, I kinda find it hard to believe.
Anyway has anyone got this issue and come up with a solution?
There are sizeable gaps front and back even with the new rubber.
Old Feb 16, 2021 | 03:37 AM
t/aws61985's Avatar
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
Re: C&C TTops leaking.
To put this short. You need to basically remove the seals, and stretch them more to fill the gaps. CnC made all the T-Tops for the fox body mustangs as well, and because of this, TTop seal installs on the CnC F-Body cars have more in common with the foxes than the GM TTop cars.
Old Feb 16, 2021 | 03:41 AM
t/aws61985's Avatar
Engine: Slow ones
I have a T Top 83 Mustang GT, and had the same issues. Here is a super old picture before the resto. As you can see. Same design.
Old Feb 16, 2021 | 01:02 PM
KR81's Avatar
Good idea, thanks for that, I'll give it a shot.
Old Feb 16, 2021 | 06:49 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I cringe at the thought of removing the seals and tearing them. eek.
Old Feb 16, 2021 | 09:39 PM
KR81's Avatar
I'm fairly certain when I installed them a while ago, that they only had like double sided tape type stuff on the new ones to hold the ends down on the ttop glass, I don't recall using any type of silicone or anything just for this very reason, so I'm hoping they're relatively easy to remove.
KR81
Feb 9, 2021 07:46 PM
vargasjc
Exterior Parts for Sale
Mar 25, 2017 06:50 AM
compuwiz1937
May 14, 2008 06:35 AM
white91formula
Nov 29, 2003 11:15 PM
trans_am_ta_84
Nov 27, 2003 03:36 PM
