Third gen build help
Old Mar 11, 2021 | 10:23 AM
Formy_WS9_89's Avatar
Car: 1989 Pontiac Firebird Formula WS-6
Engine: 305CI TBI
Axle/Gears: Not sure Haven’t looked up vin code
I got a 89’ firebird formula. Hard top 5 speed car all original. I want my car to be a street car. But it will see it’s fair share of track use. Drag racing and road course. My goal is to build the car with 500-700 hp. It’s going to be a long process and it won’t happen overnight yk. I plan on putting a 8 point roll age, Alston inner sfc and umi 2400-R sfc. Lowering springs, Panhard bar betting rear end, traction bars, wonder bar and any other bolt in suspension I can do. And my question is will the cars chassis be able to hold this type of power bc these cars flex so damn much. Will it hurt the car? I want to be pushing the safe zone for the car but I also want the car to be ok. Any help would be greatly appreciated. I just don’t want to ruin the car. Thanks everyone for taking a look.
Old Mar 11, 2021 | 11:44 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Third gen build help
Weld-in subframe connectors are one of the best things you can add to your car to strengthen it. A cage or roll bar will help too. The wonder bar is good for stopping frame cracking at the steering box.
Old Mar 11, 2021 | 01:11 PM
BOTTLEDZ28's Avatar
Transmission: A4
Take a look at Detroit Speed Inc. They have a lot of knowledge in this area. But, like mentioned above, a set of weld in subframe connectors is a start.
Old Mar 13, 2021 | 10:42 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
My '87 had SFCs welded in early on at some point in its life and when the car is up in the air you can tell the body is rigid, like able to balance on three jack stands rigid. Also don't buy cheap jack stands because knowing your IROC can balance on three of them is not something a guy should know... lol!
Formy_WS9_89
Jan 1, 2021 10:36 PM
antman89iroc
May 3, 2018 05:32 PM
diego1103
Dec 18, 2008 05:45 PM
Charged350
Oct 22, 2007 06:31 PM
erictheviking
Aug 23, 2002 10:55 AM
