1987 GTA Aerowing hardware
Old Apr 27, 2021 | 08:10 AM
Dante Kelly's Avatar
Is there hardware available to install an after market fiberglass aerowing? I was thinking using heilcoils to hold piece of metal to hold that would slide into the mount that is around the windshield.
Old May 13, 2021 | 08:57 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: 1987 GTA Aerowing hardware
In the pockets where the mounts would go run a screw into the middle of that pocket and then slide the wing into the slots, if it look like it needs to be brought closer to the glass, carefully remove the wing and run the screws in a bit more. Did mine like this and it worked fantastically.
Old May 13, 2021 | 09:08 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
i bought my hardware from hawks. it was about 15 dollars
Old May 14, 2021 | 09:39 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
I used screws on my brother's GTA wing when I put a fiberglass one on it. It worked just fine. 3 years later, it's still perfect.
Old Aug 16, 2021 | 09:57 PM
r0t0rdr1ver's Avatar
Car: 1987 IZ, 1990 IZ, 1992 GTA
Do you have a link by chance? I need the hardware too and can't find it on their website.
Old Aug 16, 2021 | 10:17 PM
Car: 1984 T/A
Engine: LQ4
i just called them and asked for the hardware
mantaguy
Members Firebirds
Aug 27, 2012 03:09 PM
SuperGT
Canadian Region
Oct 7, 2004 12:34 PM
firebirdkid
Jan 14, 2003 08:26 PM
