Brand new door rubbers ,,Wont close now
Car: 1982 z/28 Right hand drive
Engine: 377 AFR195 750DP Solid cam 10.25:1
Transmission: TH/350 3200 stall spohn conversion
Axle/Gears: 10 bolt 3.42:1 Eaton Trutrac.
Bought Brand New Door Rubbers from summit, quality is very good.
Had the car painted few months ago,, decided to replace ALL the door rubbers,, EVERYTHING went on perfect now doors wont close and i dont close or even look like closing,, 3 inches from closure the new rubbers kick in and i a not forcing the door or cutting the new rubbers.
where to next.
where to next.
Car: 90 Formula / T-tops
Transmission: MD8
Re: Brand new door rubbers ,,Wont close now
Are you referring to the seals that are mounted to the inside of the door and wrap around it starting from the mirror all the way down, under and back up to the door latch and proceed to the top? they should be very soft and spongy. got photos?
There the ones..
The doors are aligned perfect with all the gaps 100% correct.
There brand new and i put grease on the front part near the side mirror end of the rubber.
The section on the right is the problem..screw holes lined up perfect though, all the fasteners fitted perfect, all the plastic plugs went in correct
Tight as an old boot...door wont close
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
That is typical of reproduction weatherstripping...
All this chinese stuff is crap..AND its not cheap either.
i have see chrome dip sticks where the chrome flaked off and got under a bearing.
chinese dipstick $15
New motor $4500
New motor $4500
Transmission: MD8
hard to tell from the photos, but the rubber should be kind of like foam. not rubbery, but very soft rubber. can you squeeze it in easily?
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
I just did new door seals, window seals and sweeps and its really hard to close with window up and easier with window down a bit this should ease as seals get used to the pressure
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
slam the door closed and leave it closed for a few days
that shoul solve your dilemma
Engine: 4++,350 & 305 CIs
Fairchild is the brand closest to oem fit look and feel.
Car: 1987 Z28 IROC
Engine: 6.2L
I ordered a pair of Goodmark GMK402242582P door seals to try. When they arrived there was a Goodmark sticker on a set of Soffseal seals. I am kinda disappointed because I have used the Soffseal in the past and found them stiff and oversized.
But to find any door seals right now can be difficult so I will keep them and use them.
I do have a set of Fairchild t-top seals coming though.
