Replacement glass for rear hatch
#101
Car: 89' Firebird
Engine: 3.4L V-6
Transmission: 700-R4
Axle/Gears: Whatever came stock!
Re: Replacement glass for rear hatch
I think the 4 bolts were pretty well evenly tightened. I'm at a loss. I'm wondering if the heavy weight of that aero wing plays a part. Maybe I should go back to the 82-85 KITT Style, https://www.hawksmotorsports.com/198...-reproduction/
I looked on Hawks for weights of the reproduction aero and standard, but they don't give them. Think I'll email them.
I found a repro in the junkyard and snatched it up lol the mounting is super different from the factoy one.....
IMHO It feels just slightly heavier than the standard KITT style spoiler which is on my 89
The stock KITT spoiler is fiberglass apparently as I found while sanding it and kinda messed it up and had to use bondo to fix it LOL
they say t use standard Firebird hatch struts when you swap to the fiberglass wing reproduction so Im guessing the stock wing is heavy???
#102
Car: 89' Firebird
Engine: 3.4L V-6
oh man the repro stock spoiler is almost 400.....get a used o> one from the junkyard for like $30 lol
#103
What I don't know is if the orig aero wing holes on the deck lid would match up to a traditional spoiler (KITT).
#104
Car: 89' Firebird
Engine: 3.4L V-6
The aero wings have come down. They were $600-$700 not long ago. I found something that said the fiberglass aero is about 1/4 the weight of the old plastic and that the original plastic was about 40 lbs. If that's accurate, then it's 30lbs less weight on the hatch. My aero is pretty much decayed so when I take the hatch off (whats left of it) I'm going to discard the aero and just go w/o a spoiler until I"m ready to do the body work. Although, I am thinking of having the fiberglass spray with bedliner material instead of painting. It would look a bit more like the vinyl wrapped of the 86/87 and not scratch up so easily. Thoughts?
The weight seems accurate...I was gonna say maybe 7 - 10 pounds. for the repro wing.
Depending on the bedliner...the spray on in a can ones get kinda dirty / hard to clean / fade....and polisihing won't be easy if at all possible i used them before BUT they are pretty durable.... the pro kine liner that seems to resist fading more is heavy / thick.
You could paint it semi flat fro ma can? That way maybe you can polish it when it fades..I did that, turns oput pretty good.
the holes between the two spoilers do NOT line up. There are issues with fitment on the repro aero wing from what i have read though. But with no glass, now would be the perfect tiome to decide to drill / weld up holes. Or grab a decklid / spoiler if you cna find one?
#105
#106
Car: 89' Firebird
Engine: 3.4L V-6
Oh I thought you meant the aero and Kitt style haha
Still though, the holes could be off...there are fitment problems with the repro...lots of fitment / gap problems etc... The one I found appeared to have another set of holes drilled etc.. It should be at least close though.
#107
#108
Car: 89' Firebird
Engine: 3.4L V-6
Yea that is what I meant, KITT vs Aero. I am literally chasing my tail around in a circle!! I found a red 1991 Firebird hatch on a car in Ft Lauderdale. Still no way to get it home (won't fit in Jeep) but it has the standard KITT wing. That's the only one with a pic that's even remotely close to me. I have a bid request out on UShip. The new glass in NH is the solution, if I can get it to FL. The ironic thing is a very close friend lives about 10 min away from the part and has a GMC Envoy SUV that would haul it. But she can't take time off work. I'd pay her gas and hotel if needed. Her GMC also has 200,000 miles on it so I wouldn't want to risk it anyway.
I don't think it'll fit in an envoy?? The glass is almost wide as the Firebird which in itself is wide. and don't forget the wheel well arches in the envoy (just thinking of all things) Kinda think youd need to flatbed it tied down etc....
Keep in mind the 91 has the third brake light mounted at the top of the glass from the inside vs outside . on the decklid like 90 - 86 )86 is on the top outside)
#109
#110
Car: 89' Firebird
Engine: 3.4L V-6
Or a full sized pickup!!! Need about 50 x 55 inches. That's with the rear lid on. The car I saw on line for parts has the 3rd lite mounted under the spoiler. https://www.lkqpickyourpart.com/part...model=FIREBIRD If you end up on the home page select zip 33458 then search. It will default to their Palm Beach site. Scroll down and search Ft Lauderdale. It's there.
BUT if its under the spoiler and indeed a 91..... then the hatch at some point has been swapped.
It coming in as showin a 1990 search so those would be under the spoiler though
Regardless though it should fit, but the ones wired with the light on top have different wiring etc...
Does it look like it has a 91 bumper?
#111
It won't show me anything lol
#112
https://pypimages.azureedge.net/carb...max&quality=35 Try this image.
#113
Car: 89' Firebird
Engine: 3.4L V-6
That is def not a 91...I don't think its a 90 either. It looks like it has an older perhaps 87 steering wheel. Unless someone changed the bumpers, headlights, steering wheel, and even the seatbelt holders, i think thats an 87ish model...the wheels ae also the older i think 85??-87 non GTA rims... isaw this only ONCE and wish I got them here lol
not that its a problem since it has the hatch still.
the hatch bolts look rusty though.
#114
Car: 89' Firebird
Engine: 3.4L V-6
For me personally Id buy that and drive that as is!
I see the rust on the A- and B pillar though...and i see a ton of rust on the lower rear quarter....
but Id drive that lol
#115
Yea it's an 87, got my salvage cars mixed up. It's hard to tell how bad the rust is from lousy pics they posted. But its the only hatch within a few hrs drive of me. I'd like to swap out the 90 steering wheel and airbag crap for a standard 3 spoke like this car has.
#116
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
[QUOTE=you COULD in theory drive there hatchless with somebody........, and install lit and drive back home! Is that legal / doable??[/QUOTE]
el camino.......
el camino.......
#117
i contacted Hawks to ask about their hinges and if there were any additional instructions / tips for installation. i included links to the couple threads on TGO about the glass shattering after installing them. i bought these hinges awhile ago but haven't installed the hatch on my project car yet. the last thing i want is the hatch breaking and scratching the fresh paint. Hawks reply was that the problems in the TGO threads was definitely installer error. the only instruction they gave was to tighten the body side bolts with tools but the hatch side bolts should be hand tight.
#118
COTM Editor
Received 1,860 Likes
Car: '89 Firebird
Engine: 7.0L
Hand tight is meaningless. I use my hands to tighten everything. Need a torque spec.
There's a term called finger tight but I doubt that's what they mean.
#119
#120
Chilton book #28602 says 11 lbs torque at the hinge to glass location. I've read elsewhere this is too tight especially if replacing with the billet hinges (Hawks Motorsports site says "hand tight.")
#121
COTM Editor
Car: '89 Firebird
Engine: 7.0L
#123
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Here is a link to a copy of the '88 Firebird service manual. I haven't read it closely, but there appears to be a detailed writeup how to install the glass beginning on page 1748.
https://www.thirdgen.org/forums/tech...ce-manual.html
#124
#125
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Here it is (see attached). This is my own copy I've had for many years. No troubles with Mac computer. Never opened it with a Windows machine.
Edit: Hmmm.... it won't attach for some reason.
#126
It pays to dig thru boxes. My TA came full of stuff. A 1990 service manual (falling apart) included. It has a detailed section on the back hatch but doesn't really tell me more than the Chilton. But of course, service manuals have always been very poorly written and horribly illustrated!
#127
I still think polycarbonate might be the solution. It will flex, but never shatter. It's tougher than hurricane impact glass. The problems with exposure to the elements are a problem, and supposedly Optic Armor says you can't actually open/close the hatch once installed. I can only think that has something to do with flexing/bowing at the hinge to glass location. It seems there is a big problem with exploding hatches and there's another thread on here about that.
#129
At 1/4" thick, the plastic should have no problem taking whatever stress there is. This is providing the properly spec'd lift struts are installed. You could even go so far as to use it without struts I would think.
Maybe there's an issue with how the deck lid gets attached the it can't be used in a normal sense because of that?
I've just tossed out a request for information from Optic Armor. I'll post back with what they have to say.
I hope they respond.
#130
I still find that difficult to believe.
skinny z (07-24-2021)
#131
OK. This is the disassembled metal rear deck lid. This is the plastic cover that goes under the lid, and under it another metal piece then the glass. What the heck is that rusty bracket? It appears to be riveted to the lid. Any sources of new parts? Also my aero spoiler is totally rotted. The metal bands that go around the glass are good, but the clips that hold the wing to them are rusted out too. Source for parts?
#132
From Jim Dunham:
Thanks for your interest in our products. If you mount the window to the factory frame it can still be functional. Let me know if you have any more questions. Thanks again!
So, there you go. Here's hoping someone here gives it a go.
#133
Here's a follow up from Jim at Optic Armor:
The windows are designed as a drop-in, cut to factory glass dimensions and formed to factory curvature. If they want to mount them to the frame and make them functional, they will have to drill the hinge holes which is very simple to do. Also you will want to swap out your gas struts since you will be removing around 50 pounds from the hatch.
#134
I am still waiting to hear back from Optic Armor, but it was also the weekend. All 8 holes (the four in the rear lid area included) would have to be perfectly drilled which might be an issue. I doubt my insurance will go for the Optic Armor though, you know insurance companies even the good ones!
#135
At one time, I was using the gas strut catalogue and determining my own spec for hood struts as I went to fibreglass. But it's been so long, I can't even recall the manufacturer but that's easily determined with a look for branding on the strut (my heap is in storage so I can't check). IIRC, they are spec'd by length, travel, lifting capacity and attachment methods.
As for the drilling, polycarbonate is simple enough to drill but some kind of template would be needed. Most likely patterned after the original glass. A little difficult to do though when then original is in a million pieces!
Not sure of the metal bracketry. I don't recall what the underside of my hatch looks like.
#136
#137
Judging by the vibe I get from Optic Armor's e-mail, I think their market is primarily the racer. They describe the application as being a drop in. As such, I can see it being pinned down with a handful of Dzus fasteners rather than the functional approach.
Keep in mind, that the metal frame is key to making the polycarbonate hatch work and I think it would make good sense to determine the OEM glass thickness and select the plastic hatch to suit. I think their thickest is 1/4" which sounds about right for the frame.
#138
#139
I think you will find plenty of 3rd gens at the race track. More now than ever. I'm one of them. And any racer knows that being lighter almost always equates to being faster. Except the guys who race on salt. Then weight is their friend.
#140
LOL tells you how much I don't know about racing! I would think all glass on any race car would be polycarbonate though for safety. The only racing I've seen is Outlaw and Midget class (if I remember the names right). Dirt track. Very dusty. Fun to watch though.
#141
Car: 89' Firebird
Engine: 3.4L V-6
Which metal clips that hold the wing? Pics?
The aftermarket spoilers atttach at the decklid and use 2 really small (I dunno how they actually do anything) clips that keep the wing attached to the hatch.
#142
The pic above is the side of the plastic bottom piece that goes under the rear lid. Between it and the glass itself is another large metal retaining bracket, but that piece is not rusted. This little piece is which is easy to fix but it appears to be riveted on. You can see the little "white" circles near the top and bottom. It would only make sense to POR 15 both sides so rust doesn't happen again.
#143
Car: 89' Firebird
Engine: 3.4L V-6
The Aero Wing clips. Mine totally disintegrated although my wing is rotted out and I don't think I'm putting it back on. Hawks sells a fiberglass replacement that comes with clips. I am worried about the edge banding that screws into the rear lid though. If I end up with a hatch off a salvage car it might even have the traditional 1982/KITT spoiler which not only looks better but is far lighter than the wing.
If you mean the slot clips on the hatch glass trim, or the clips on the wing itself, I don't think ANY repro wing uses those.
I used to not like the wing, but now I really like it lol
the KITT style is great too, but ionly like it on the early non ground effects T/A and base Firebirds
#144
"The Aero Wing clips"
#145
These are on the plastic lower section of the rear deck. If you opened the hatch, the clean side is what you would see. The reverse side, which helps sandwich the glass, has this long metal bracket. Obviously, this rust in unsat and I want to POR 15 it. But, it attaches with some sort of tiny rivet. Once removed, I'll need some other means to secure the metal piece to the plastic. Why can't GM keep it simple??
#146
Car: 89' Firebird
Engine: 3.4L V-6
thats on the plastic trim that covers the bottom of the decklid correct?
I think that is just for the rolling cargo cover. the little notches on the cover sit in those openings.
My 89 has that...the 87 doesn't have that or the cargo cover. prolly just to give the plastics more support to pull the cover out.
#147
#148
Car: 89' Firebird
Engine: 3.4L V-6
tiny bolts / screws. would be easiest.
I don't think that piece wil likely rust to the point of falling apart though given that its also on the inside of the car....kinda like the under dash brackets etc...
IMO I'd coat the back with POR and leave it.
You might do more harm removing it from the plastics and trying to reattach it by making the hole too big etc... its possible nuts on the other side will interfere with the palstic sitting nicely..or contact the glass??
.02
.02
#149
.02
.02
1989karr (07-27-2021)
#150
Got the cargo cover bracket cleaned up (turns out, I still had my old rivet tool!). POR 15 tomorrow, and paint, then reinstall. I am wondering if anyone on here has ever shipped via UShip (there's a new glass in NH I would like to get) or a company called Toro Logistics Group (TLG) I think out of CA. They're a broker also, not an actual shipper, and their reviews are bad. https://www.uship.com/service-provid...lg-freight-usa
