Anyone running shaved door locks?
Old Jan 21, 2022 | 08:09 AM
Soupyman's Avatar
If so where did you put an unlock switch and how did you do it.
Old Jan 21, 2022 | 11:44 AM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44, Tru Trac, 3:73 gears
Re: Anyone running shaved door locks?
The car has power locks with a remote fab. In the event that I lose power, the key lock is still behind the license plate and the battery is in the rear compartment under the floor hatch. I’m not sure how often I will lock this car since I will not be leaving it unattended, but they work just in case I do.
Old Jan 22, 2022 | 04:54 PM
Soupyman's Avatar
what remote fob are you using, if I decide to do that i want to know a good one
Old Jan 22, 2022 | 08:12 PM
soloc4's Avatar
I’m using the Dakota Digital unit for the simplicity, it tied directly into the power lock solenoids at the kick panel and I also tapped into the trigger wire for the rear hatch release since it passes through that area.
bungo78
Jun 3, 2011 07:04 PM
adampousson
May 26, 2006 01:24 AM
Error404
Jan 31, 2004 07:06 PM
