ground effects shouldered studs
Old Feb 22, 2022 | 02:45 PM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
I am needing to replace the shouldered studs on my 84 transam ground effects.
They look a lot like the shorter ones in this set.
My question is, does anyone have a part number for just the shorter bolts.
if not, do you think I can just cut down the longer bolts from this set?
https://www.classicindustries.com/pr...E&gclsrc=aw.ds
Thanks,
Chris
Old Feb 22, 2022 | 06:21 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: ground effects shouldered studs
I can't find a p/n for the stud because it's part of the spoiler and yes you can cut the bolt ,just make sure you have a bolt on it so you can back it off to keep the threads clean
Oddball
Jul 26, 2019 11:18 AM
peterc005
Dec 1, 2011 04:55 PM
