Water-based or enamel?
Car: 85 t/a
Engine: 5.0 tpi
85 TA.. brown/ gold. The sticker thing with the paint codes is gone from the console. I found the paint codes online (I'm trying to order touch-up) but it lists 2 codes for each color, one with a W and one with an E.. for water-based or enamel.. how do I tell if i need the W or E? I hope i explained that well enough.
Car: 1984 Trans AM
Transmission: 700-4r
Re: Water-based or enamel?
if car was built in California, for sure, it is water based. Other states could be lacquer . My '84 was a Cal car & painted water based.
Car: 85 t/a
Engine: 5.0 tpi
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
By the 1980s, lacquer was no longer being used by American auto manufacturers...
Car: 1984 Trans AM
Enamel is called single stage = paint only. Old school.
Lacquer paint was used in the past, especially hot rod projects where many coats were applied for depth of shine. The paint, the better the shine. Auto manufactures used lacquer back in the '80's. Paint tends to web crack over time.
in the vin, the 11th character would be, as an example N = Norwark L = Van Nuys
My '84 TA was built at Van Nuys
Car: 85 t/a
Engine: 5.0 tpi
thanks
Car: 85 t/a
Engine: 5.0 tpi
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Van Nuys is in California and Norwood is in Ohio.
Car: 85 t/a
Engine: 5.0 tpi
It's touch up paint. It's not going to be right. It's going to be "Oh well. Close enough. I can live with that."
