Driver side manual mirror
I’m at a loss of what to do. My third gen is in amazing condition and the stupid manual mirror broke, the glass is wobbly and won’t stay pointed in one spot and I don’t wanna replace the mirror cause then I’ll have a stupid mirror that doesn’t even match my paint job. Any solutions on how to fix it? Or not make it wobble. If not
does anyone have a manual flame red metallic driver side mirror?
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: Driver side manual mirror
yull need to see what is broken. pics help.
if its not internal to the housing you can replace the glass portion with a used unit
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Could be in the mirror housing or the little joystick components in the door. Or both. I had to repair both. Fiddly but worth it in the end. If I can figure out how to post pics I will. If the door mounted part is broken check in the bottom of the door for missing bits.
