Drivers door removal(risk to hinge adjustment’s)
Old Nov 26, 2023 | 05:47 PM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Axle/Gears: 3:42 open diff
Hello everyone, I’m in the middle of prepping my car for a new paint job. I was wondering do I have a risk of knocking the hinges out of adjustment if I loosen the bolts. I know that gm cars are a nightmare to readjust. Here are some pics, I would greatly appreciate some help
Old Nov 27, 2023 | 09:23 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Re: Drivers door removal(risk to hinge adjustment’s)
In order to paint a vehicle completely, doors, hood, truck lid/hatch have to be removed. Back in 2009, I had my '72 Buick GS repainted. I had removed the interior, glass, exterior trim, etc. The body shop remove the doors, hood, trunk lid & separated the door hinges from the body & doors. Any capable shop can reinstall the door & hinges & align them properly.
Old Nov 27, 2023 | 09:25 AM
Abubaca's Avatar
Doors are easy to remove, and to my knowledge, there's not a lot of adjustment on the body side. I've had my doors off on a few of my thirdgens and never had any issue with realignment. They were always as good as they were when removed. An extra set of hands it more less mandatory though.
Old Nov 27, 2023 | 12:20 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Hinges are welded to the doors. Iirc, the body side has a small hole on top and bottom that doesn't allow for much adjustment unless its been drilled bigger.
Old Nov 27, 2023 | 12:31 PM
ACebell's Avatar
Car: 1983 Camaro Z28
Engine: Originally LU5, but now Carb'd
Transmission: TH350
Axle/Gears: 323
I'm right in the middle of prepping for paint myself. I already tackled replacement of the door bushing. No need to worry about alignment too much on these cars. As previous posts say, there is not too much adjustment on the hinge flanges that bolt to the body. Just scribe where the hinges are bolted into the body and remove. With the help of a set of extra hands, and or an engine hoist.
Old Jan 9, 2024 | 09:17 AM
KCG's Avatar
KCG
Car: 89 IROC
This thing is a life saver if you're working by yourself.
TheMysticWizard
Sep 7, 2010 07:56 PM
Firebat
Mar 2, 2008 08:13 PM
85berlinetta2.8
Interior Parts Wanted
Jun 19, 2006 07:42 AM
GndPrx
Car Audio
Nov 29, 2001 01:47 AM
