Windshield wipers binding
Old Jan 11, 2024 | 11:04 AM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
I removed my windshield wiper motor and linkage to paint the engine bay and cowl area on my '89 'Bird, and now that I have reinstalled the parts, the wipers don't work.
The motor turns on, but the wipers only move a few degrees, not even close to a full sweep.
It seems as though the linkage is binding, but if I disconnect it from the motor, I can move the wipers by hand.
I have tried adjusting the linkage via the slots on the rod by the motor with no change.
I have tried two other known good motors, also with no change.
I don't understand how I could put the exact same parts back on and have a problem.
I'd appreciate any help or questions anyone has.
Thank you .
Old Jan 11, 2024 | 11:08 AM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: Windshield wipers binding
If you disconnect the wiper linkage does the motor spin freely? It sounds like the linkage is clocked wrong and reciprocating at the wrong point.
Old Jan 11, 2024 | 01:29 PM
capted60's Avatar
I had the same problem. I had the wiper linkage on wrong. Disconnect the linkage where the 2 screws hold it together and move the linkage for the wipers so the wipers will move up a bit then re-attach the linkage to the motor with the 2 screws. Hard to explain but you can attach the linkage(with the 2 screws) in 2 positions, one wrong which will bind up. The holes will line up both ways. Good luck.
JonJon5.0
Apr 26, 2019 01:27 PM
IROC_5796
Jun 29, 2005 08:59 AM
Kandied91z
Sep 17, 2004 06:53 AM
