Lower radiator support bent straight up - best way to bend it back down?
Old Feb 19, 2024 | 10:23 PM
ryguy32789's Avatar
Car: 1984 Z28
Engine: 305 HO
I have a new-to-me 1984 Z28 Camaro. When I bought it it had a janky aftermarket mechanical fan instead of the oem electric fan. I tracked an OEM fan down, and it doesn't fit, the lower mounts don't line up. That's when I noticed the lower radiator support is bent straight up, directly in the middle. No other visible damage. I did notice it also has an aftermarket radiator. I suspect somebody at one time tried jacking the car up from the lower rad support and ruined the support, electric fan, and the radiator.
Anywho, what's the procedure to fix this? I was going to take the radiator out, stick a 2x4 in there, and wail on it with a sledgehammer, does this seem reasonable or is there a better, less violent strategy?
Old Feb 20, 2024 | 12:41 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Re: Lower radiator support bent straight up - best way to bend it back down?
Do you have a picture of how it is bent?
Old Feb 20, 2024 | 09:33 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Good question. The metal will be "stretched", so without a way to "shrink" it, you may struggle to get it 100% straight. Without some hydraulic tools or floor anchors, I think I'd just apply a 2x4 as wide as the opening, and a large hammer.
Old Feb 20, 2024 | 11:54 AM
ACebell's Avatar
Car: 1983 Camaro Z28
Engine: Originally LU5, but now Carb'd
Transmission: TH350
Axle/Gears: 323
I'm all for grabbing the hammer and trying to pound the heck out of it to get it back to shape. But maybe? A 2/4 and a 1/4 and a few big C-Clamps first to see if you can easy the offending bend back into shape?
Old Feb 21, 2024 | 07:22 PM
erik69&85's Avatar
I had the same problem... Yep... A 2x4 and a heavy hammer... Get it down so it does not interfere anymore... If you work it well... It's not really noticeable....
The bottom on my rad was bent... But not leaking... Didn't trust it so I got a replacement.
Old Feb 21, 2024 | 11:06 PM
ryguy32789's Avatar
Car: 1984 Z28
Engine: 305 HO
Now this is an idea I can get behind. Definitely going to give this a try.
Old Feb 22, 2024 | 07:14 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
As said, 2x4 and hammer. It's sheet metal, not a structural I beam so it'll move easy, won't be perfect but it'll move.
miche25
Apr 22, 2019 03:40 PM
8587ta
Nov 16, 2016 04:29 PM
FirenScuba
Sep 5, 2009 09:07 PM
