Hood touches bumper before locking, how do I fix it?
Old Mar 21, 2025 | 04:05 PM
BigBean's Avatar
Getting the car painted in a few months so I'm starting to work out all the stuff wrong with the body. Was sitting for 26 years until last summer.
The hood will sit on the bumper before it locks, and I always have to give it an extra push down, bevause the hood always touches the bumper the paint has chipped and rust has formed.
how do I get the hood to lock out before touching the bumper?
Old Mar 21, 2025 | 04:10 PM
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
Re: Hood touches bumper before locking, how do I fix it?
Raise the latch.
Old Mar 21, 2025 | 04:13 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Probably need to shim the bumper forward slightly...
Old Mar 21, 2025 | 05:09 PM
BigBean's Avatar
Ok thanks that did the trick. I think I will replace the latch soon though as it has some play after it locks (If i press it down some more it will still touch the bumper, even though its locked)
Old Mar 21, 2025 | 05:12 PM
BigBean's Avatar
How would I shim it foward? I see what you are talking about
Old Mar 24, 2025 | 06:56 AM
exiled350's Avatar
There should be two bumpers on the core support to prevent the hood from going down further than it should. Make sure they're there and maybe raise them up if they're all the way down.
Old Mar 24, 2025 | 09:26 AM
T.L.'s Avatar
The impact bar already has shims from the factory. IF it needs a couple more, you can probably find some used ones from parted-out cars...
Old Mar 24, 2025 | 11:29 AM
gbeaird's Avatar
Car: 1985 Firebird & 1992 Camaro B4C 1LE
Engine: 310 LS1. & 305
Transmission: TH350 & T5
Axle/Gears: 9" 3.73
As exiled noted above, there'll be two adjustable bumpers on the core support that should allow you to put some positive pressure on the hood latch if you run them up a couple of turns. Here's a picture of the front left one on our race car, for reference.
Luis1991
Nov 23, 2024 08:31 PM
Soupyman
Jan 19, 2022 04:48 PM
captainchadl
Mar 26, 2014 06:55 PM
87camaro kid
Dec 26, 2002 11:11 AM
91TealRS
Aug 12, 2002 12:15 PM
