Paint code
Old Mar 28, 2025 | 05:22 PM
wbrainerd's Avatar
Car: 1987 Pontiac Firebird GTA
Engine: 460 BBC
Transmission: TH400
Axle/Gears: 3.9:1
Paint code
1987 Firebird GTA, I have no Service Parts Identification Label so I cannot know for sure what my paint code is. I think it's a WA3967 Cotillian white but I have no way to verify other than to buy some paint and try it.
Any other way to know?
Old Mar 29, 2025 | 01:36 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: Paint code
Pretty sure 3rdgen white in 1987 was called, simply, White. RPO code was 40. And the color code was WA8554.
Old Mar 29, 2025 | 09:07 AM
wbrainerd's Avatar
Engine: 460 BBC
Transmission: TH400
Axle/Gears: 3.9:1
Re: Paint code
Thanks for the help. It APPEARS, from reading various sources, I have a WA 3967 White (Cotillion).
Old Mar 29, 2025 | 09:23 AM
wbrainerd's Avatar
Engine: 460 BBC
Transmission: TH400
Axle/Gears: 3.9:1
Re: Paint code
WA8554 Is a white clearcoat
WA3967 is a white cotillion
Not exactly sure what the difference is, I'm not a paint guy. Maybe someone can comment and clarify this???
Old Apr 10, 2025 | 09:28 AM
wbrainerd's Avatar
Engine: 460 BBC
Transmission: TH400
Axle/Gears: 3.9:1
Re: Paint code
An update for those in a similar situation. My paint code ended up, through deduction and comparison of several paints (dupli-color), being a 11 gm code WA3967. Dupli color EBGM01387. I compared that to the WA8554 (code 40) EBGM03387 and found the code 40 white too white compared to my TA. Dupli color calls it (WA3967) a white "Cotillion" but has now dropped the Cotilion from their vernacular. Many thanks to Roger at Dupli Color. I also went down the path of using the GM Heritage WEB site (GM Heritage Archive | General Motors) where you can provide a VIN and they will pull up an original build sheet from their archives for $50. In my case all I wanted was the paint code so the $50 wasn't worth it but others may get allot of use from that site. There are ALLOT of sources to determine paint codes with many of them conflicting with each other. Dupli color seemed to be most accurate in my case but you can always have a paint supplier make your color too if you can provide a good sample.
Anyway, appreciate all the help.
Old Apr 16, 2025 | 03:00 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Paint code
there was only one White for 87 WA8554---40
1986 Chevrolet Color Codes - Camaro Paint Cross-Reference THEN GO TO YEAR 87
bigbird89
Jul 11, 2008 08:56 PM
crrllmich
Sep 27, 2005 08:22 AM
