aftermarket steering wheel problems
Old Jan 25, 2002 | 08:32 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I have a 92 Z. when I built the car it had a blown airbag, so I bought a grant wheel. 13 1/2 inch I think. the problem is it seems that the steering is tight now and not as responsive as the factory wheel. I barely had enough threads on the center bolt to tighten the nut down. if I back the nut off any it will be to loose. I bought the install kit for an 89. I though the 92 application was not avalible because of the airbag. Was I wrong Is this my problem. Has anyone else had the same problem. I also had to trim the plastic houseing on the column to keep it from rubbing. Help!!!!!!!!!
Old Jan 25, 2002 | 08:45 AM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
When I installed mine I remember reading that it would not work on cars with an air bag, so you might be right, i am at school so i dont have access to my paperwork. I am pretty sure that is your problem.
Here's mine:
Old Jan 25, 2002 | 08:59 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
hey thats the same wheel I have except for the cover. I want to get a leather cover that you can sew on. maybe blue or gray. are those the glow pedals? where did you hook the wires upto if the are?
Old Jan 25, 2002 | 09:20 AM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
i hooked up the pedals to the courtesy lights so they come on when i open the door or i can turn the ****. (btw - removed the bulbs from my courtesy lights, and when i get a pass underdash panel i am putting a 10 inch tube under the passenger side, looks cool as **** when the tube is hidden and all you can see is the light (my friend did that)
Old Jan 25, 2002 | 09:44 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
we used black lights back in 1989 in our cars, made it a little hard to see out a night. it hurt my eyes. I want to use blue or purple tubes under my dash but how is the new tubes on the eyes while driving
Old Jan 25, 2002 | 12:45 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
i usually dont have the pedals on while driving becuase i have a 1o inch tube overhead on the same curcuit and since its blue its kinda illeal to drive with that on
the tube is not under the passenger side yet, i currently have it wires into curcuit for the hatch but once i get the underdash panel its going up front becuase i have tubes around my wallmart woofers that i am going to wire up through the hatch curcuit.
Old Jan 25, 2002 | 04:08 PM
Blue502's Avatar
You might need to get an 89 or earlier column and install that if you want to keep that wheel. Shouldn't be all that expensive or hard to do, I got my column replaced for $150 a few years back.
Old Jan 27, 2002 | 09:26 AM
brihoop's Avatar
stuart69427... I like that steering wheel! where did u get it and how much did it cost you???
Old Jan 27, 2002 | 06:24 PM
HrdRockA4305's Avatar
Hey I just got that same steering wheel today! Cost me $42 from auto zone, then the $15 adaptor kit. Coulda got it from Jegs just as easy, but why pay shipping when you don't have to? It'll go on sometime this week. I've been meaning to do this since the first day i got the car... that base model steering wheel is just ugly IMO. Plus it matches the color of the car
Old Jan 27, 2002 | 08:24 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
got the wheel on ebay for $20 plus $8 shipping, $15 for the kit and $8 for a puller.
btw - the leather cover i had already, but costs $8, IMO the best cover man could buy
Old Jan 28, 2002 | 07:59 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I got my wheel from advance auto. was about $52. I could have ordered it cheeper. I thougt about taking the wheel off and grinding the install kits aluminum block down for more room to tighting the retainer nut down more. and also grind where anything is rubbing. this may help.
Old Jan 28, 2002 | 02:59 PM
Camaro_hunter_d's Avatar
I have a 92 RS. I got the same Grant wheel as above. The biggest prob I had was the bolts with the kits did not want to fit so I had to go to lowes to get some that would. I did tap the wheel on with a plastic face hammer though.(the directions never said that would be the easiest way to get it on tight!) I did not even bother with that damn rear trim piece that was in the install kit. It did not fit(Too big).
Old Jan 28, 2002 | 06:30 PM
brihoop's Avatar
ya, i have that cover on my wheel now...it is GREAT!!! but what is the puller???
Old Jan 28, 2002 | 09:43 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
sterring weel puller, i should have just attemted to do it with out it
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
