Urethane Bumper Primer
Old Feb 16, 2026 | 06:36 PM
69-er's Avatar
I have repaired the deteriorated areas on the bumper covers using a flex-fill epoxy filler. After feathering out the areas, I am not too sure how well they will look once paint is applied.
On steel panels I always go over my repairs with epoxy primer, then Featherfill and/or a urethane primer-surfacer to get it flat.
I plan to use epoxy primer first as I understand it will adhere very well to a urethane bumper. Is there an equivalent high-build sprayable product that can be used here? I have heard of high build epoxy primers.
My reasoning is I would just like to be able to block the entire surface to ensure it's flat.
Any thoughts?
Old Feb 18, 2026 | 08:41 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Re: Urethane Bumper Primer
Look to see if the brand primer you want to use has a flex additive like this, https://products.axaltacs.com/dcat/u...uct/4950S.html
DirtDawg57
Sep 10, 2012 02:53 PM
Dustytrix
Jun 24, 2011 02:03 AM
customblackbird
Apr 14, 2011 09:09 AM
JohnC
Dec 16, 2007 07:02 PM
camaroman_83
Jul 26, 2004 03:24 PM
