What holds the headlight knob assembly in place?
Old Jan 30, 2002 | 03:57 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
What holds the headlight **** assembly in place?
I pushed my headlight **** in to turn my lights off and it just gave out. I looked all behind it and everything. The **** is attached to a metal rod, which goes into the dash I guess you could call it, where it goes into a box. Well, whatever is supposed to hold that box in place obviously isn't there anymore. What should be there and how do I fix it? PLEASE help!
Old Jan 30, 2002 | 07:06 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
it's a little black clip right behind the ****. i found this out at a junk yard after pulling the SOB off and cutting my finger on it. i had to pull like hell to get it off.
Old Jan 30, 2002 | 07:56 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Remove the **** and shaft as a unit. There is a release button on the bottom of the headlight switch. Pull off the hush panel (the plastic trim below the dash) then use a flashlight and a long screwdriver to push the button. Pull on the **** while you press the release button. The shaft is triangular shaped as I recall. Lon
Old Jan 30, 2002 | 10:05 PM
Does this black clip attach to the back side of the black panel that the rod runs through? Does it just hold the rod or does it also have a support for the "box" behind there?
Old Jan 31, 2002 | 08:12 PM
ttt
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
