need straight up answer on t-tops
Old Jan 31, 2002 | 01:00 PM
91rsrider's Avatar
ok i busted one of my t-tops yesterday trying to get ice off of it,so it doesnt melt and leak into my car.it cracked from the outer edge to the inside.i managed to get it taped up with 3 layers of masking tape,and it seems to be holding up pretty good.so i was wondering if anyone knows for sure that glass t-tops will or wont fit plastic t-top cars.ive searched and seen some very blurry answers.ive seen that some years wont interchange,and some will.does anyone know for sure??I NEED HELP!!!
Old Jan 31, 2002 | 01:09 PM
Drew's Avatar
Here is the deal, All GM ttops are the same size. GM changed the design several times and they aren't all interchangable without adjusting the mounting points. Get a set from the same year car and they should fit. Either way just make sure that you don't get stuck with a set that won't fit your car. Ie try them first or make sure the seller has a good return policy.
Old Jan 31, 2002 | 02:36 PM
Blue502's Avatar
Just make sure you get a set of factory t-tops with the pin style latch (not the 82-83/84? hook style latch) and not a set of aftermarket tops like Cars & Concepts. Look at how your tops latch for reference. If you do that, they'll fit.
Old Feb 1, 2002 | 08:26 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
MEASURE THE Width of the metal between your T-tops and your Windshield.
The Factory T's windshield frame is about the same width as the "A" pillar. The Aftermarket ones that I have seen, the windshield to T-top is about 5 inches, almost twice the width of the A pillar. (the A-Pillar is the piller between the door window and the Windshield.)
Go to www.sunroofdoctor.com they have some info on this topic. I THINK there is only 2 DESIGNS, Factory & C&C (Cars & Concepts)
Trivia question for all you guru's out there, Did you know that C&C actually developed the Banchee Concept car for Pontiac. I was at there facility here in Michigan (when they were in existance) and they had the Banchee sitting there in the back room. I actually got to sit in it too
oh well enough gloating..
Good luck...
Old Feb 1, 2002 | 10:17 AM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Axle/Gears: 3.23 Posi
Sorry to hear about! I would do like the other guys said and try to stick with factory and if possible around the same year and latch style. I am lookin forward to seeing your car man, hope she gets better....
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
