Rust question...
Old Feb 5, 2002 | 07:32 PM
Blade69's Avatar
Rust question...
how much rust is to much rust for an 84???? are there sighns that the car is going to be a rust bucket in ten years??? and is there any kind of treatment that i could put on a rust spot to keep it from spreading???
Old Feb 5, 2002 | 10:40 PM
orange rocket's Avatar
Wheres the rust? How many winters has it seen? Where is the car located? I have a 83 L69 I am resatoring right now and it came from Massachusetts. However rust isn't real bad because I can tell most winters were inside. I have some holes here and there but regular to less than regular amout. Now interior is out and I'm sand blasting the whole car. Need details to help
Old Feb 6, 2002 | 01:49 AM
Blue502's Avatar
If you have serious rust in the rocker panels or in the frame structure (especially where suspension components connect) then you have real problems. Any major rot in the rear quarters, rear wheel wells or floor would also spell disaster in my book. You can use POR15 to stop rust, but it only works completely if you can cover both sides of the metal if it is rotting from the backside out. The sooner you kill the rust the better. If you have holes, you really need to cut and weld.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
