will the steering "colum"?? out of a 86 z bolt right up to a 84 z?
well thats my problem,there is good steering colum in my parts 86 z,with delay wipers,but i dont think it has cruise,or at least it doesnt say anywhere on the switch,and my 84 does have cruise but i never use it anyways,but the wiper and turnsignal swith on it is broken,so will all the wires work just fine?or what will i have to change to make it work,i know ill have to switch thewiper motor,but is that it??thanks alot for your time..
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The design of the steering column changed several times from 82-92.
According to the parts & service manual, from 84-86 they appear to all be the same the only differences will be with or without tilt, with or without cruise, with or without delay wipers, etc.
My guess would be that you can probably interchange all the parts but the tilt/non-tilt columns are definately different. but the turn signal actuators etc would be interchangable...
hope that helps
John
hope that helps
John
hey thanks for your help,but let me get this right,your sayin that the wiring harness should connect without any problems at all???thats pretty much the only thing im worried bout,cuz the only thing different on them is that the one has cruise and the other one has delay,thanks alot again.
Options and appearance changed between years, but they will all interchange (at least through '89, airbags may have severily changed things). I have a column out of a Monte Carlo SS in my '86 Camaro.
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
