91-92 front end
Old Feb 9, 2002 | 01:00 PM
Beefy89's Avatar
91-92 front end
Anyone know if a 91-92 GTA front end will bolt right up to an 89 GTA? Thanks
Old Feb 9, 2002 | 01:08 PM
BirdonFire's Avatar
I am not 100% sure,but I would say no.
Old Feb 9, 2002 | 02:09 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The hood is the same, the Fenders have the same part numbers, so I would think that it should work, you will need almost everything else though...
John
Old Feb 9, 2002 | 04:35 PM
Blue502's Avatar
Yes, it'll bolt right up. You'll end up with a set of holes on the front of the fenders though from removing the earlier style gfx.
Old Feb 9, 2002 | 04:39 PM
BirdonFire's Avatar
I was thinking that the headlight and the headlight buckets would interfere with it.....hmmmmm...I could be wrong.
Old Feb 9, 2002 | 05:16 PM
okfoz's Avatar
ACTUALLY, the headlight will work, but if you do the conversion, the bezel from the 82-90 will hit the front facia. If you remove that they will work.
The headlights kind if changed in 91-92, so if you find a donor car, get the headlamp assemblies. They changed all of the hinged parts on the headlights for 91 & 92. The bracket that bolts to the body, the motors & the little arms that attach to the motor & such seem to be the same though...
John
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
