t-top weatherstrip question
Old Feb 9, 2002 | 09:10 PM
mckenzie's Avatar
i just installed the t-top weatherstrip in my camaro today. i used gm weatherstrip and i have a small leak. when standing outside the car looking in, where the weatherstrip on the t-top itself meets the weatherstrip on the car on the right side leaks when i spray water on it. i have everything lined up. used directions from this board and also the directions that came with the weatherstrip. according to the directions with the weather strip, i may need to adjust the window. anybody else had this problem or can give me any suggestions on adjusting the window. thanks, tom
Old Feb 12, 2002 | 02:44 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I guess I should ask, How does it leak, or better yet, where does it leak.
If it leaks and drips on the passenders leg, then that might be an adjustment issue. If it drips on the back seat then that would mean there is a seal issue, and you should seal up the gap between the body panels and the seal itself..
hope that helps...
Old Feb 12, 2002 | 02:54 PM
silentneko's Avatar
mine just started dripping on my seat, my sun visor and headliner are wet to, what do I do, I armoralled it but I have no idea if it will leak again, it never leaked before.
Old Feb 12, 2002 | 03:25 PM
okfoz's Avatar
top leaks are a real pain to locate. really ahrd to say without seeing it... sorry...
John
Old Feb 12, 2002 | 05:53 PM
mckenzie's Avatar
on mine, if you look at the drivers window from outside the car, its in the upper right hand corner where the t-top seal (the seal that is attached to the t-top) connects to the seal on the body. thanks, tom
Old Feb 12, 2002 | 06:54 PM
okfoz's Avatar
If it sounds like its an adjustment issue.
to do it you take out the screw for the interior trim and use a 7mm nutdriver to adjust the cams.
thats best I can do without looking at it...
John
Old Feb 12, 2002 | 07:18 PM
mckenzie's Avatar
thanks, okfoz. i have adjusted it the best that i think i can. i'm going to try to adjust the drivers window and see if it makes a difference. the forward part of the window looks like its up higher than the back. thanks, tom
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
redmaroz
Aug 16, 2015 11:40 PM
