broken trunk latch motor
Old Feb 21, 2002 | 10:42 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
hey guys
i have a broken trunk latch motor..................since the Z28 is mainly gonna be a street/strip car...........i wanna know if i can put in a non power hatch latch???
was there ever such a thing for 3rd gens??
will one from a 4th gen work???
Old Feb 21, 2002 | 11:26 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
They have a different bolt mounting pattern. But I did pick up one from a Pick-A-Part that had the older style slam latch bolted onto the gutted frame of a pull-down style. It would take a little work to get the right height, but it can be done. Lon
Old Feb 21, 2002 | 11:28 AM
un4givin89's Avatar
Yeah, I ordered a slam latch just to find that out. You have to weld and cut out the other one and weld the new on in its place, major pain in the ***.
Old Feb 21, 2002 | 01:20 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
my car doesnt have that stupid trunk motor! :lala:
i think 85' and older didnt have em.
i know your pain tho, i had problems with the trunk motor in my formula. The motor was broken so i just had to slam it REALLY hard.
Old Feb 21, 2002 | 08:59 PM
damn, guess i'll have to shell out some major bucks for a new motor
Old Feb 22, 2002 | 12:46 AM
lonsal's Avatar
Not necessarily. I can e-mail you some scans from my HELMs manual so you can diagnose and fix it. Also just dissabling the unit and slamming the hatch is a bad idea. The motor housing is plastic and attached to the frame with 3 screws. It will soon fail with the shock of slamming the hatch. Once broken away the unit will just float around loose. If you want to repair the hatch pull-down unit, parts are available (I stock them). I suppose I need to start offering a conversion kit for those that want to swap it out for the older slam latch style unit. That is a rigid metal unit and is up to the task. I'll pick up some more pre-86 latches my next trip to the Pick-A-Part and work on the conversion kit. Lon
Old Feb 22, 2002 | 06:17 AM
Saywhut's Avatar
On the brackets:
I retrofitted the Bose radio rear cover to mine, it had specific brackets that I cut from the donor with a chisel, then popriveted to mine, they're behind the taillites so they don't show.
The pulldown bracket, if riveted, would be covered by the license plate, and I'd suggest painting the drilled hole, for rustprevention, and the rivets after installation for appearance, as I did. This should allow retrofitting any hatch pulldown assembly I guess, without welding.
I ground a chisel specifically for this purpose, it now looks like a ramp (only 3 sides instead of 4) and works well to cut spotwelds.
Just a thought.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
