The Very Best Adhesives
Old Feb 23, 2002 | 08:32 AM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
Since there are different types of materials in our cars, one adhesive will not work for everything. What are the best adhesives for:
ABS PLASTIC
RUBBER
CARPET
VINYL
METAL
I've had very good luck with JB weld, but it sucks having to mix it up.
:hail:IROC-Z
Old Feb 23, 2002 | 08:02 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Go Here:
<A HREF="http://www.3m.com/us/auto_marine_aero/aad/catalog/">3M Catalog</A>
If you spend some time on their site you can find the answers to all of your questions. These are pro products.
<B>«««««««««««»»»»»»»»»
<FONT SIZE="2" COLOR="red">Red 86 T/A </FONT><FONT SIZE="2"> 5.0 TPI (LB9/WS6)</FONT></B>
¤ HyperTech Cap/Coil/Rotor/AFPR
¤ Derale Adjustable Fan Switch
¤ 170&deg; Stat ¤ Flow Matched Injectors
¤ K &amp; N Air Filter ¤ Ported Polished Plenum
¤ Runners ¤ TB ¤ Polished Wheels
¤ Alternator ¤ Fuel Rail ¤ SLP TB Airfoil
¤ Pirelli 245/50/16 ¤ All Else Stock
<A HREF="http://www.gmtips.com/3rd-degree/">Tech Site</A> ¤ <A HREF="http://v.webring.com/hub?ring=3rddegree">WebRing</A> ¤ <A HREF="http://www.gmtips.com/3rd-degree/dox/3rd-award/awards.htm">Car Award</A>
<A HREF="http://www.gmtips.com/3rd-degree/"><IMG SRC="http://www.gmtips.com/3rd-degree/cg/3rd-logo.jpg"ALT="Tech Tips" BORDER="0"
</A>
Old Feb 24, 2002 | 06:20 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I guess it depends on what your trying to do and for what
for carpet to a hard surface, or a headliner to the board I would recommend using some sort of spray adhesive. There is 3M 77 which is nice because you can reposition it, but it does not seem to hold as well as the 3M90 which is not re-positionable. There is also headliner spray that can be bought at some upholstery material suppliers which works well, but it seems to clog up the sprayer.
If you want 2 hard surfaces like metal to plastic, you will probably need some sort of epoxy, or JB weld. You will need to look at the label to determine if it is compatible with both your materials.
metal to metal is a welding or screw together thing, you can epoxy but I am not sure how long it will last.
If your doing plastic to the same type of plastic, you will almost have to research this one because there are different methods for every type of plastic out there.
does that help?
John
Old Feb 24, 2002 | 07:22 PM
Nightcruzer's Avatar
Car: Trans Am
for most plastic parts look here
Old Feb 24, 2002 | 07:30 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Also found this
<A HREF="http://www.fusor.com/productmetal.htm">Fusor Products</A>
For bonding metal to metal as well as some other plastics.
Old Feb 24, 2002 | 10:42 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
Great info. Thanks!
:hail: IROC-Z
Old Feb 25, 2002 | 05:38 PM
anotherfastcama's Avatar
I would have to say the best adhesive ihave used would be PL Premium. I work for a construction company and the only thing that it doesn't stick to very well would me MAKITA tools plastic. I use it for sub boxes redoing my hedliner the only down point is that it takes to long to Dry
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
tcflint
Sep 14, 2015 04:55 AM
Omega
Aug 10, 2015 12:46 PM
89-28gp
Feb 8, 2003 06:50 AM
Tom Keliher
Aug 5, 2002 09:04 PM
