For what reasons could my foglights not worK?
I just bought the car and neither light works. I am asking b/c tomarrow I will probably rip the grill off to try and follow the wires and see if I can figure out why. Any help would be greatful.
Wes 87 Iroc
Wes 87 Iroc
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
what car? you talking about driving lights or fog lights? either way id check the bulbs and the fuse first
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
if its the actual fog lights your checking, just remember that they will need a grounding wire since the front bumper covers are fiberglass. so check that they have a ground wire and that it's grounded properly.
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I'm not trying to be a smart ***, but make sure they are turned on. It would suck if you pulled it all apart only to realize they were turned off.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If I am not mistaken some cars you ahve to have the parking lights on, or the headlights on for the foglamps to operate. HOWEVER, if you have the brights on they will not light...
My dads caddy is like that
John
John
thanx for all of y'all help
I think it's the relay. I pulled it off and it had corrosion all over it, I tried to clean it off, but I heard rattling in it, so I'm assuming that it's the relay.
Wes 87 Iroc
Wes 87 Iroc
eightsixseven
Dec 16, 2024 01:50 PM
NinjaNife
Aug 23, 2015 11:49 AM
