Torque, Torque to much...... Seat Bolts
Old Feb 28, 2002 | 02:56 PM
GoldenSwordZ28's Avatar
*** damnit, I got my new 4th Gen Seats, and when I went to torque the drivers side seat down, guesse what I went and did? Yep, torqued the bolt into 2 peices.... lets keep count of all the things that I've torqued to death so far:
1) Wheel Stud
2)Air Cleaner Wing Nut
3)1/2" Drive Extension
4)Seat Bolt
Now, all of these so far have been repairable, BUT, with this new addition to my casualty list (The Wheel Bolt) I can't see how in the name of G0D I am gonna be able to get the MF'er out to put a new one in. So, how do I fix this guys, cause lemme tell ya, this REALLY sucks.
Thanks guys
Adam
Old Feb 28, 2002 | 03:18 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Your best bet would probably be to drill it out from the bottom, and use a nut and bolt in place of it. Also, use some large washers, and some silicone to seal up the bottom.
Old Feb 28, 2002 | 04:48 PM
Spindr130's Avatar
Well at least u didn't "torqued to death" those dam bolts on the distrubutor cap. man i did that 4 times wat a huge pain in the butt.
Shaun
Old Feb 28, 2002 | 05:43 PM
Hehe, well, at least those aren't welded down like I think the Seat Bolts are. Well, I think there under a welded peice at least. This is gonna suck MAJOR *** me thinks.
Adam
Old Feb 28, 2002 | 06:05 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Actually this should be pretty easy. It happened to a friend of mine years ago with a Trans-Am. You have to drill it out but make sure you use the right bit. At first my friend and I were drilling constantly and pushing on the drill but not getting very far. It was real slow going. Then we went and bought a cobalt bit for hard metals(I think that's the type it was) After that it went so fast it was a joke.
Old Feb 28, 2002 | 06:31 PM
After you drill it out, then what? The bolt is in there upside down....how do I get the new one in??
Adam
Old Mar 1, 2002 | 05:57 PM
So theres no way to get to the bolt from under the car or what not? Even Drilling? Man, I need to get this fixed, but I don't know where to start aside from knowing that I have to drill. And other tips would help here.
Adam
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
zayne0
Aug 24, 2015 07:22 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
