ac/heater lights??
Old Feb 28, 2002 | 08:11 PM
brihoop's Avatar
ac/heater lights??
i was wondering if all camaros have the ac/heater controls that light up when you have your lights on? i have an 88 and the do not light up so its hard to tell what you are doin at night, but the other night i was in my friends 87 and noticed that his lights up. so i came home and took mine out to see if the bulb was burned out or something, but i didnt see any bulbs or anything??
Old Feb 28, 2002 | 09:04 PM
Joe91Z28's Avatar
Well not sure if they all do, but mine lights up. I believe it is a 194 bulb, you'll find it after you remove the trim piece that goes around the pod. Drove me nuts til I replaced it!
Old Mar 1, 2002 | 06:03 AM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
like joe91z28 said, its a "194" bulb in the back, top right side of the hvac controls.. to change it, take the front cover off, i believe there are 4 screws (t10 or t15 torx or philips or 7 mm bolt.. i know its one of those three) holding the control pannel.. pull out the pannel.. the light will be in a holder with 2 wires (black and tan, i think) goin to it.. twist it and pull.. replace the light.. reverse the order to put everything back together..
mike (loomdog)
Old Mar 1, 2002 | 09:14 PM
brihoop's Avatar
thats the problem i dont see a bulb at all when i take the stuff off!!!
Old Mar 1, 2002 | 09:27 PM
87_Camaro's Avatar
i have the same problem guys, i don't see a light bulb, its like coming from the ac box thing itself, can someone shed some light on this problem?
Old Mar 1, 2002 | 09:54 PM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
Is that a pun? lol
My light comes from a small bulb mounted on the lip of the dash just over the ac/etc. controls..there's a little white-looking plate over it, pull sof, and the bulb replaces...
Old Mar 2, 2002 | 12:53 AM
Azure's Avatar
Dammit, SOMEONE has to find that funny...
*BUMP!*
Old Mar 2, 2002 | 12:30 PM
irocEOK's Avatar
hey, the bulb is right behind the controller assembly. I had to
replace mine once too. Just pull off the wholeface plate, the pull out the heater/ a/c controls a lil bit, and its in the back of the unit. just one measly little bulb. I personally feel there should be 2 for better illumination.
Old Mar 2, 2002 | 12:37 PM
87_Camaro's Avatar
well thats just crappy, is there anyways to make it brighter?? it does look dim and ugly if you ask me
Old Mar 3, 2002 | 02:54 AM
loomdog32's Avatar
Car: 82 Camaro Z28
u could use a high output bulb, but i might look a little funky.. one side would be really bright and the other would be kinda bright..
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
