T-top nosie at high speeds
Old Mar 4, 2002 | 12:07 PM
jawzforlife1's Avatar
When i get up to 70mph the wind blows between my t-tops and windsheild. Somenody one said to unscrew the black plastic peice on top on the T bar, them lossen some screws and make an ajustment to another peice, then put it all back togther. Is this right
Old Mar 5, 2002 | 06:05 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
sounds about right, you take out the 7mm screw holding the trim piece and lower it, then there are 2 more 7mm screws that adjusta cam, loosen them and adjust down, then re-tighten...
Of course If your not getting any leaks it Might be possible your hearing the turbulance from the air going over the gaps between the t-tops and the roof of the car....
John
Old Mar 5, 2002 | 10:30 PM
I do get leaks.
Old Mar 6, 2002 | 07:42 AM
okfoz's Avatar
ok, then do as above
John
gta90
Sep 15, 2015 04:00 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
Penultimo
Camaros Wanted
Aug 20, 2015 08:42 PM
BBSDesigns
Aug 11, 2015 07:39 PM
