removing side markers
Old Mar 20, 2002 | 05:01 PM
5.0L1992RS's Avatar
I am trying to figure out how to remove the side markers on my camaro. It is probably so simple that I am just overlooking it. Also, where could I get some clear side markers?
Old Mar 20, 2002 | 05:12 PM
1982chevycamaroz28's Avatar
you have to go thru the engine compartmen to get to them. there should be like cut out holes where the washer fluid tank is and the marker light is being held in with 2 clips on each side and i think u can just use sum needle nose pliers and just pull on the middle of them. and the same goes for the other side. i forgot how to get the tabs out but u should just be able to pull on the middle of the clip but if that doesnt work the get like a screw driver and pry them back so the like losen up for u to wiggle them out. im not totally sure on how to get them out. its been like months since i changed mine hope that helps.
Old Mar 20, 2002 | 05:49 PM
Wes B.'s Avatar
There is a pin that you flip up and take off so the side marker can come out. As far as where to get clear corners, the only place I've found (and where I got mine) was at www.procarparts.com Hope this helps.
Wes
Old Mar 21, 2002 | 05:48 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
I have searched EVERYWHERE for the clear sidemarkers, and procarparts.com is the only place that carries them. The cool thing is that Sylvania makes the bulbs in different colors so that you can match them to the body color if you want. I think the bulb number is 744, although I'm not sure. You can look it up on their website.
Old Mar 21, 2002 | 06:05 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
If your engine compartment is crowded, you might find it easier to undo the clamps on the back of the markers from underneat.
Regarding the clear corners - they're on ebay constantly (from that same company I think though!).
Ken
Fronzizzle
Aug 17, 2015 02:52 PM
Street Lethal
Aug 14, 2015 08:25 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
