T top Alignment
T top Alignment
Is there anyway to align a t top better or adjust it. My passenger side fits fine but the drivers side seems to be set to far forward causing a gap in the back of the seal where the corner of the window makes contact. Any help would be greatly appreciated.
Thanx
Thanx
The only real adjustment I can think of is if you take off the T-tops and look below the hole they lock into, there is a screw that will move the hole up or down. That is the only adj. I can think of.
