Ground effects
Car: 91 Z28 Convertible
Engine: 305TPI
It shouldnt be too hard at all... just a bunch of bolts. do a search in this board at the bottom of the forum page. there are a lot of topics on it.
I just got done taking them off my 92 z it is extremely easy there are 6 screws when you open the door, there are about 6 10mm bolts under the car that go on little brackets then from the inside of the door behind the fender there are 2 11mm bolts. and behind the interior panel under the speaker/sail panel ther is one bolt that goes through to hold on the ground effects. you will have to dig through some sticky cork stuff to get at those. but it took me like 20 minutes to do both sides.
hope this helps.
hope this helps.
Damon
Sep 26, 2015 04:29 PM
