brake lights wont work got pulled over
Old Oct 29, 2007 | 11:19 PM
danny14gnx's Avatar
they light up but dont get brighter when you hit the breaks its a gta trans am thinking its the break swtich but what are the 5 wies comng to it for? any info would be greatly appreciated
Old Oct 30, 2007 | 06:47 AM
Re: brake lights wont work got pulled over
If the turn signals work, it's probably a fuse.
The actual brake light switch should have 2 wires: one orange, and one white IIRC. The other sounds like part of the cruise (a complete discrete separate entire assembly added onto the basic car).
You should have 12V on the orange wire, and then 12V on the white wire when you push the brakes.
If you have that, then the fuse is OK and the switch is good. Next place for a fault would be the turn signal switch, since that "lifts" the light that needs to blink off of the brake light circuit, and switches it over to being supplied power from the flasher circuit. That hardly ever goes bad though.
Old Oct 30, 2007 | 07:44 PM
danny14gnx's Avatar
k thanks its not the fuse thats the first thing i checked not bulbs either
Old Oct 30, 2007 | 07:47 PM
So, what about the 12V at the various points?
Old Oct 31, 2007 | 01:12 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Which fuse did you check??? The TAIL fuse (which powers the tail lights and the insturment guage lights) or the STOP/HAZ fuse (which powers the stop lights and the hazzard flasher)???
And the bulbs you have are two element bulbs?
It could be the switch that is bad. As sofakingdom noted you shoujd be checking the 12v power along the circuit until it disappears. The wire color for the brake lights from the switch should be LT BLUE, not White as sofakingdom mentioned.
Also, does your car have the thrid brake light? If so, it will be a seperate circuit, from the brake switch, than the tail brake lights.
Dave
Old Oct 31, 2007 | 10:51 AM
camarocamaro22's Avatar
Car: 87 chevy camaro
Engine: 5.7
Transmission: automatic
i believe sofakingdom, it should have 12V on the orange wire, and then 12V on the white wire when you push the brakes. If thats not right, im not too sure whats going on.
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Omega
Aug 10, 2015 12:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
